Yamaha Tracer 700
Novosti, komentari novih i starih motora...
navig8
Stoper
Stoper
Vozim: Kawasaki Versys 650 LT
Yamaha Tracer 700
Post by navig8 » 27 May 2016 08:54
Ne vidjeh da je neko pisao o ovome modelu, a uskoro se pojavljuje na trzistu u regionu. Vjerujem da ce lagano naci svoje mjesto u klasi izmedju 650-750 cc, mozda direktan konkurent Versys-u, NC750X itd. Svakako lijepo izgleda evo kacim par slika i nesto o njemu sa neta:
photo sharing
image upload no limit
upload img
Technical specifications
Share
Engine
Engine type - 2-Cylinder, 4-stroke, liquid-cooled, DOHC, 4-valves
Displacement - 689cc
Bore x stroke - 80.0 mm x 68.6 mm
Compression ratio - 11.5 : 1
Maximum power - 55.0 kW (74.8PS) @ 9,000 rpm
Limited power version - 35.0 kW 7,500 rpm
Maximum Torque - 68.0 Nm (6.93 kg-m) @ 6,500 rpm
Lubrication system - Wet sump
Clutch Type - Wet, Multiple Disc
Carburettor - Fuel Injection
Ignition system - TCI
Starter system - Electric
Transmission system - Constant Mesh, 6-speed
Final transmission - Chain
Fuel consumption - 4.3 l/100km
CO2 emission - 100 g/km
Chassis
Frame - Diamond
Front suspension system - Telescopic forks
Front travel - 130 mm
Caster Angle - 24.8º
Trail - 90 mm
Rear suspension system - Swingarm, (link suspension)
Rear Travel - 142 mm
Front brake - Hydraulic dual disc, Ø 282 mm
Rear brake - Hydraulic single disc, Ø 245 mm
Front tyre - 120/70 R17 M/C 58W (tubeless)
Rear tyre - 180/55 R17 M/C 73W (tubeless)
Dimensions
Overall length - 2,138 mm
Overall width - 806 mm
Overall height - 1,270 mm
Seat height - 835 mm
Wheel base - 1,450 mm
Minimum ground clearance - 140 mm
Wet weight (including full oil and fuel tank) - 196 kg
Fuel tank capacity - 17.0 L
