SWM RS 650R
Novosti, komentari novih i starih motora...
VeDzA
Vozim: Yamaha XTZ 750 ST
Honda XR 400 R
SWM RS 650R
Post by VeDzA » 14 Sep 2016 10:57
Speedy Working Motorcycles--za mene egzoticnu firmu,otkri australijanac na poslednjoj voznji sto imasmo..
Firma je osnovana 1971 u Italiji,ali je propala 84',da bi je ponovo digli iz mrtvih dvojac,kineski biznismen i Husqvarnin inzinjer,svetskog glasa...
Iako mi djelovase kao jos jedan "kinez" u nizu,ipak komponente koje se ugradjuju daleko su od kineskih...
Model RS 650 R je saraf u saraf husqa TE 630,i cijena mu je oko 8000 e
U ponudi imaju 125,250,300,340 i 500 ccm modele...
Na papiru djeluje mnogo dobro(osim ovoga hoda prednjeg amortizera :roll: )
SPECS: 2016 SWM RS 650 R
ENGINE
Type: Liquid-cooled four-valve single cylinder
Capacity: 600cc
Bore x stroke: 100.1mm x 76.5mm
Compression ratio: 12.4:1
Fuel system: Electronic fuel injection
PERFORMANCE
Claimed maximum power: 53hp
Claimed maximum torque: N/A
TRANSMISSION
Type: Six speed
Clutch: Wet multi-plate
Final drive: Chain
CHASSIS AND RUNNING GEAR
Frame: Steel double-cradle
Front suspension: Upside-down Marzocchi, 210mm travel
Rear suspension: Sachs monoshock, 269mm travel
Front brakes: Twin 260mm discs with twin-piston Brembo calipers
Rear brake: 220mm disc with single-piston Brembo caliper
DIMENSIONS
Claimed dry weight: 144kg
Wheelbase: 1506mm
Ground clearance: 249mm
Seat height: 899mm
Fuel capacity: 12 litres
NikGold
Vozim: Uvijek prljavu Hondu xr650r
Re: SWM RS 650R
Post by NikGold » 14 Sep 2016 12:04
Kinezi kupili staru tehnologiju husqvarne . Husqvarna je sada ktm
+1389+
DrMracni
Vozim: KTM 990 Adventure
KTM 350 Freeride
Re: SWM RS 650R
Post by DrMracni » 14 Sep 2016 13:17
Prijatelj jedan ih uvozi na trziste Hrvatske, tako da ih i mi mozemo dobiti. Mislim da bi ovaj 650R bio oko 7500€
Ljudi nemojte da jedete zuti snijeg!
http://www.monteguide.me" onclick="window.open(this.href);return false; - Motorbike Tours Montenegro https://www.facebook.com/monteguide/" onclick="window.open(this.href);return false;
NikGold
Re: SWM RS 650R
Post by NikGold » 14 Sep 2016 13:41
dzaba, daj dva odmaa
+1389+
sLowRider
Vozim: GO!!!!!!!
Re: SWM RS 650R
Post by sLowRider » 14 Sep 2016 17:49
Moze i na kredit, zna ja jednoga te daje
Hold your horses, man
Freeride
OgArD
Grijač guma
Grijač guma
Vozim: Suzuki DL650 V-Strom
Re: SWM RS 650R
Post by OgArD » 17 Jan 2017 10:05
Za te pare mozes kupit i Husqvarnu :D
